Hey Steve,Hello Gerry, don't worry about my patience, it's not infinite but neither is it limited when someone needs help.
Sorry I can't be more helpful right now but, given the constraints you appear to be working under, I do not see how your conflicting requirements can be met and nor do I understand how your engineer could propose a strapping plan that would square that circle given my understanding of the frames structure and potential condition. That said, I would be happy to be proven wrong so please share his/her plan.
- Strap Positioning- the issue here is; your need to continue using the house while stabilising its structure to prevent further damage.
- To my mind these requirements conflict with each other insofar that any sensible positioning of the essential straps will significantly inhibit/prevent day-to-day use of the bedroom in particular as the primary strap would need to run between the two posts at the front and rear and ideally near the top of the posts forming the slipped bent just below the level of the top plate.
- Has your engineers indicated just where in the frame he/she would site the suggested straps and what purpose each of these would achieve/contribute to stabilising the structure?
- I would remind you that any straps connected directly to any of the horizontal timbers in the frame runs the risk of serious damage to M&T joints the current condition of which are entirely unknown.
- Bents/Stick Built - Your measurements seem to confirm my present thinking that it's a timber frame rather than stick built. The post that has slipped off vertical would be somewhere near that 12 foot mark from the gable wall.
- Ceiling Hatch - for the future it would be useful for you to have such access to allow inspection of the roof timbers. But, some thought about its siting will be needed and getting a frame in place to support it may be problematic as it must not be linked to other timbers in the roof that may have shifted when the post slipped - you do not want to add stiffenings that may inhibit the movement of the frame back to its original position.
