Cubist
Hi Gerry,
Sorry but we need to be careful about the terminology. A 'collar tie' is a beam morticed into both truss/rafter members below the apex of the bent. If you look at the cross section diagram of your house that you provided earlier, the collar tie is represented by the top-most horizontal line. At 14 feet x 4 feet I think you are talking about the flat ceiling that someone has installed below the collar ties in two adjacent bents and their trusses.
To establish what repairs are needed, close inspection is vital. Sorry, but all the plaster work currently covering the the two truss members, the collar tie, and the heads of the posts on both sides of the bent must be removed. However, you should not need to remove more than a foot of the plaster into the room from beside these timbers to provide all essential and required access. So no need to take it all down.
Investment of a few pounds for a decent borescope could save you a lot in this and other projects.
I think you may want to consider how best to finish the room after you see the final results of the repair work and how these may appeal or not to your aesthetic tastes.
I'm a little pressed for time right now so I'll come back tomorrow concerning props and straps.
Cheers for now.
Steve
Cheers for now.
Steve
