One possible source of wet air in your loft is a central heating header with an overpressure release pipe feeding into it. I have seen these steaming away in lofts....
If you don't have such a thing then that's that.
How much of the roof was replaced in the 90's ? any original hardwood timbers left? If so the water may well be activating any dormant fungal spores. As for leaving that alone have a read through your insurance policy regarding fungal attack. :-(
Lots of lofts are experiencing moisture issues with sustained freezing temperatures and little wind to force ventilation; the cold air cannot support the same vapour as usual and has little opportunity to blow away, the roof structure, timber and felt are all at ambient cold and will readily gather condensation. In other words, yes you can have destructive levels of simple condensation, especially in the situation described with blocked vents, inadequate underfelt vent space, and ready pathways for warm moist air.
For now, seal the access traps as best you can. In the spring get some scaff up and strip the part of the roof which is at issue. Remove any rot from timbers or replace/repair if too far gone. Fit rigid foam insulation between rafters leaving 50mm gap below felt line,Breathable membrane, battens, tiles back. If your ceilings are plasterboard knock them out and add more insulation inside, then new ceiling. That should give you 75 to 100 mm of effective insulation without losing too much headroom inside. If your ceilings are lath and plaster you have to make a call on fabric conservation value vs thermal and moisture comfort ( ie just have a bit of insulation behind the ceiling).
If your structural timbers, wallplates and/trusses are rotten and wet in the spring you must get a suitably qualified and experienced person to examine them and advise on repair or replacement.
Sorry if this sounds a lot, but forewarned is....etc. and what I am describing is about as bad as it could get :-(
