Our previous owners were fans of ornate woodwork and 'half panelled' one room, bar a gap behind the radiator. While I'm 99.99% sure we'll be covering the gap with bookshelves, we decided to make good the gap when we removed the radiator.
Without a planer/thicknesser I've had to fiddle around shimming standard stock to get the panels right, then finally to mitre in the beading. Knowing how rubbish I am with a handsaw and having seen my chippie use a chop saw for almost everything I bought an almighty sliding compound mitre saw for this and other jobs (total cost less than 1 day of chippie time).
So I measure carefully, cut one mitre measure again to check cut the other mitre, repeat and discover they don't meet at 90 degrees ?!?
Top Tip #1 - You must hold the beading the same way up on the saw for both 45 degree cuts or you end up with a piece of expensive kindling.
Lesson learned I measure, cut, measure, cut can't work out why the bead keeps ending up 3-4mm too short?!?
Tip #2 If the laser sight on the saw is aligned for left hand feeding then when you feed the second mitre from the right you need to account for the 3-4mm thickness of the saw blade.
Still it was only 2 lengths of bead at £4 a pop and a few hours of my life....
