Penners
- Suffolk, England
I've always felt that criminals should be forced to spend their prison term pointing. It would cut re-offending rates dramatically.
That tool carries the somewhat pejorative name of a "plasterer's small tool". (joechip said:the smaller pointing trowel ....This tool is a must have and I used it for 95pct of my pointing.
Nemesis said:Merlin is beautiful. I am currently catless and feel a trip to the animal rescue place required.
joechip said:As for the fire, the picture may make it look better than it was as the insert was very shallow and the fire smoked a lot when used. It also did not provide much heat unless you were sitting right in front of it. We are going to install a small multifuel stove in it's place which I have been told and hope will serve us a lot better in the cold winter months (and it gets very cold up here).
Penners said:joechip said:As for the fire, the picture may make it look better than it was as the insert was very shallow and the fire smoked a lot when used. It also did not provide much heat unless you were sitting right in front of it. We are going to install a small multifuel stove in it's place which I have been told and hope will serve us a lot better in the cold winter months (and it gets very cold up here).
A multifuel stove is a worthwhile investment for a number of reasons. But if the lack of warmth from a smoking open fire is the only reason, then I would give it a chance to prove itself, before you write it off.
Once you've installed a hearth, a grate and a good fireback, and got the chimney well dried out, you may find that the open fire will be greatly improved.
joechip said:Robin, for the floor we have bought slate tiles. They are uncalibrated but luckily do not vary in thickness too much. They are an African slate with multiple colored veins of reds , blues, blacks and golds. I like them a lot and think they will work with the room.
Back on the subject of tiles. Does anyone have any experience with tiling over concrete floors. My floor is not in the best of condition but not broken or cracked, mainly just dusty and a little brittle on the top layer in places. What do they do before laying the tiles, do they seal the floor with something? Also do I want to use a dpm which is something you read a lot about on tiling guides. Also does anyone know, if I am not having skirting boards, but lime down to the floor does the tiling come before the walls are plastered or after?
FamilyWiggs said:I lost a stone and a half doing the floor
