re solar with remote collection:
If you're not able to quantify cost and heat loss of a system or pipe run you'll need help from eg news:alt.solar.thermal. Theres no way you can design a solar system until you can quantify these things. Its not difficult.
"What I haven't yet seen is powered TRVs for each radiator, allowing different temperatures at different times for different rooms, controlled centrally or overidden locally,"
What I'm describing is simpler than that. It is simply an adjustable room thermostat controlling the TRV. Contro is achieved with a miniature LV heating element on the TRV.
This gives thermostatic temp control but no independant timing control. It means you can set the room temp dial to anything you like instantly, which is not really achievable with TRVs. It also means you have proper thermostatic control, which is a considerable improvement on TRVs, which are a lot less thermostatic than would be ideal.
The low cost of this approach makes it practical to make every room a separate subzone. It also gives a much better level of owner control than TRVs.
"But Legionella is something to be aware of for anything that systematically deals with water n the danger temperature range"
1. The storage type exchangers only store the water headed for the drain, so any bugs only have access to the drain.
2. The stored water is chilled by incoming cold mains water to below 20C
3. Bug killing shower/bath/sink/etc cleaners kill off bugs in storage. Bleach kills legionella.
4. Copper is biocidal, and these exchangers are usually copper.
NT
NT
