wobs
- Hull - there's a nip in the air.
I've found myself with about 20 telephone directories from last year (don't ask). Having a real fire, I've been thinking about the obvious thing of burning them, but rather than just putting them straight on, I thought I'd do a bit of experimenting.
I just happen to have a long card tube from the sash window kit, which fits the yellow pages nicely if you roll them up. I've cut the tube into lengths that just fit the yellow pages, and put 3 of them to soak over a weekend, and 3 left just dry. I also put some white pages to soak to see if it will make any difference (probably not).
When they're all dry (could take a while now!), and its cold enough, I'll see how they all burn and compare and contrast. Fortunately I also have a chimenea to test these things, incase it produces large flames (don't want to set light to the chimney!).
Should be interesting if nothing else.
If it's successful, I should be able to get many more tube to shove the directories into, to create log shaped fuel for the fire.
