fernicarry
- Argyllshire
Thanks, I will have a look at Green Build Forum, yes the ventilation (to remove moisture) issue is a big one to solve as we make builds more airtight, including period ones, ideally an MVHR unit is a good solution, even in a period property it can work, or trickle vents in windows, or a dehumidifier in the winter (running overnight on off peak tariff). Insulating beneath floorboards can be quite disruptive, however, it can really help with draught proofing between and around the boards, especially if they are exposed??
Need to differentiate between air tightness and insulation. When starting from a very low bar like many traditionally built buildings the former is way more significant than the latter. You can insulate to any depth you like, but if the wind is just whistling around it then you're wasting your time.
And for that reason I really need to get on with putting a breather membrane under my floor boards. Its scary the amount of daylight you can see from below when looking up through the gaps. That was planned for this summer, but I'm still finishing off all the other summer jobs that overran.
The HR part of MVHR is a non-starter unless you have very good air tightness. It relies on the air flow out being balanced by the same air flow back in through the unit itself. This doesn't happen when you have other ways for air to come back in.
The V part is still very desirable and necessary and can be M if you wish. I have a 3 terminal central extractor in the loft that extracts from the kitchen and two bathrooms and exhausts through the roof. It really cuts down on condensation and keeps those rooms fresh.
