Feltwell
- Shropshire, England
I'm sorting out one of the attic rooms on my house to be my daughter's new bedroom. That room contains a vanity unit and sink that we'd like to retain, it's Ikea's finest but there's nothing wrong with it and it will be useful in years to come.
This room is on the floor above where the hot water cylinder for the house is - so it has a cold supply to the sink only, with a hideously ugly wall mounted water heater above the sink if you want hot water. You have to remember to switch this on 5 minutes before you want hot water, and (bearing in mind this will be a child's room!) remember to switch it off again.
You can get undersink versions, but they are a similar design - they rely on heating up a stored tank of water. So whilst these would be hidden and could be wired into the ring main for the sockets as they're only about 2kw, you still have the problem of turning them off and on.
You can get "instantaneous" water heaters that heat water by demand only, when you turn the tap on - but most draw much more power, we already have 2 electric showers in the house so don't want to overload the incoming supply! I have seen one rated at 3.5kw - so drawing only 15 amps - how effective that would be is a question, plus also if it would require a dedicated feed from the consumer unit or if it could feed from the sockets ring main (which already supplies 2 floors of the house).
Are there any other options? Has anyone come across a way of pumping hot water up a floor (similar to a shower pump) so I could use the hot water supply as per the rest of the house?
