Flyfisher
- Norfolk, UK
JoceAndChris said:I suppose I could take a new pipe south to Coldharbour Lane but I'm different to the previous owner and would want permissions from all the different land owners who own those fields. I'm very friendly with Fiona and our pipe could perhaps go through her grounds to emerge on Coldharbour Lane. It's certainly a lot lot higher up than Beacon Lane, and if the pipe just ran straight across the fields the up part and the pump could be located in our field below the house.
From your description of things, that is starting to look like a much better scenario than trying to get the existing pipe into operation. If you really can get a mains water supply to the lowest point of your own land then you would then be in full control over things like building, powering and maintaining a pumping station to get the water up to the house.
As others have mentioned, I see no problem getting a new electricity supply connected to a pump house on your land. We had two meters at one time and before that there were three meters (one for a 3-phase supply) to outbuildings. As I've mentioned before, our new gas connection cost was £295 because we dug the trench on our land and I wouldn't imagine electricity being much different.
As for the pump, you'll need the requirements properly designed but I doubt it's a huge problem in the grand scheme of things. The previous points about flow AND pressure are good ones but if you can also provide local storage near the house then a 'trickle' flow might be adequate and things like pressuriseed showers could be handled by standard shower pumps within the house.
With good neighbour relationships you should be able to negotiate a suitable wayleave agreement (we have a number crossing our land so it's all very standard stuff) then it's just a case of laying the pipe. Depending on the land, there are pipelaying attachments available for tractors that sort of "plough" the pipe underground without even needing to dig a whole trench first and there must be specialist contractors who could do this for you.
And given that you have a £15k borehole budget to play with (I entirely agree that spending it on a borehole with no guarantees is too risky) then I'd say it's starting to look quite encouraging and it could be that your biggest problem will be to decide on a suitable design for the pumping station itself - some sort of gothic 'folly' perhaps?
