Feltwell
- Shropshire, England
JoceAndChris said:Very true. We inherited those, I guess they're around 8 years old now and completely covered in scratches that can be seen even in the gloom of my subterranean kitchen! What would you replace them with?
As Lady A said, you can't see any scratches in the pictures - I thought you'd just put them in!
What to replace with - depends how deep your pockets are.
Laminate is the cheapest and probably the most practical, being hardwearing and easy to keep clean. Huge range of colours, I would definitely avoid all gloss laminates - even those that say they are scratch resistant. Also dark colours show scratches easier than light - but if you want dark then so long as you go for a textured finish they're not too bad. My first job many years ago was running a depot of a company distributing worktops. If you go for laminate get the corners properly mason mitred, joint strips look hideous. Hot pans straight off the stove placed on laminate will ruin it, you would be surprised at the amount of business we used to get from people who had done this! Formica is the brand that everyone knows, there are many others. You get what you pay for, cheap boards are cheap for a reason.
Corian as Lady A has is lovely stuff but very expensive and definitely not a DIY job to install. Corian is a Dupont trade name, there are other versions of much the same thing. It's an acrylic polymer - although what you see looks like a solid worktop, it's generally a (6mm or so) veneer glued over an MDF sub-base. Can be joined seamlessly by a good fitter, looks beautiful and can be repaired if it gets scratched. If your pockets are deep enough it's very nice stuff indeed. Hot pans won't do it any good.
Solid wooden worktops can look very nice, but do need maintenance and do need care. Quality can vary a lot, and how you use them needs to be thought about - leave a cast iron pan on a wet section of oak worktop and you may mark it permanently. Obviously scratches can be sanded out. Hot pans aren't recommended but you will usually get away with it. A wooden worktop that has not been looked after can look very tatty very quickly. DIY install is OK.
Granite looks beautiful, best of the lot in my opinion, but don't put hot pans on it - it may crack. Obviously not DIY, and you need deep pockets.
