Nemesis
- Planet Earth
I think there is a lot of help can be given, but maybe not in public.
Surely the right way around this potential problem is to apply for LBC and BRC both at the same time - with the plans showing the windows that your CO will approve. Then, if/when you get both consents, there is no risk of either department restrospectively saying, "Oi - you can't do that."Flyfisher said:who is the ultimate authority that a listed building owner can turn to when things go wrong or become confused? If building control turns up and says that your nice new single-glazed windows do not meet the building regs, is it always the case that the LBC gives an automatic exemption from their authority?
As the emphasis of control is on protecting the external appearance of a building and the affect of alterations on the character of the area
Nemesis said:Alterations which change the character of a building require Listed Building Consent. It's not discretionary.
Moo said:Nemesis said:Alterations which change the character of a building require Listed Building Consent. It's not discretionary.
- even if the character (and aesthetic appeal) of a building has been ruined by a pre-listing alteration.
Gareth will know the building in St Giles Street in Norwich which had the original ground-floor windows replaced with some that completely destroyed the regular pattern of the facade when it was used as offices. I understand that, because it was listed after the event, when it was converted into flats the new owner wanted to reinstate the original windows but wasn't allowed to.
Gareth Hughes said:That'll have been down to the individual local authority's interpretation of the guidance (I'd probably have felt differently about that one).
GK said:Regarding applying for Building Regs and LBC at the same time (Penners) it would be possible but a fee would be payable for the building control part.
I don't think it's been mentioned in this thread that planning approval and listed building consent aren't the same. For an internal change, listed building consent (and building regs if applicable) would be sufficient, but for something that affects the exterior, planning may come in as well.
I wonder if the OP in this thread got planning approval for the windows ("I received Consent from Planning") but didn't get lbc. Planning, conservation, different departments, different criteria, they don't always talk to each other. Then there's building regs.
David Norris said:In reply to above Conservation Planning Consent was required,
