philpjuk100
- newark nottinghamshire
As I usually cut pallets up away from an electricity supply I use a chainsaw,I cut them into the three bits with blocks in,stack these and then cut the blocks out,I dont seem to hit any nails but if they are dropped off near the workshop I use a recipricating saw I was given via "freecycle"(the chap who I got it from had cut through the wire!) but its a great bit of kit! the only problem with burning pallets is all the nails that are left in the ash! I agree that a manual impact driver is not the best tool to use on cast iron if you use one wear stout gloves!DJH said:Yea, and bad jokes... :lol:
philpjuk100 said:I also collect scrap wood/pallets etc during the year and burn them.
So do I Philip. I cut them up with a jigsaw which is quieter, less dusty and the blades are cheaper if you hit a nail than using a chainsaw or circular saw although blades are available for the latter which take no notice of nails or screws. With the thinner section timber on the pallets I cut them into length,stack them up about 6 high and then fire a 90 mm nail through them ending up with a nice dry log. Simples...![]()
Doug
