"Humph" says Henry, looking over my shoulder at the screen. "That one doesn't even have a face!"LadyArowana said:On an unrelated note I see we have another fame hungry vacuum cleaner vying for attention like Zebra's Henry.
Thanks BV!I still think the wine analogy is good. You can read thousands of books, spend zillions of pounds and wax lyrical with adjectives conceived for quite different purposes.
Or you can go to the nearest supermarket and grab a couple of bottles of whatever is in the bin by the door. I can't usually tell the difference.
If you buy a bag of 'lime' from the nearest builders merchant and pretend it is cement it works just fine. Mix it dry, one part of the dry white powder and three parts of sand as dirty as you like (I fish the larger leaves and twigs out), add water to taste as use straight away. I can't usually tell the difference.
Unlike cement, if you add too much water it doesn't matter - just leave it overnight and then pour off the water that has settled out on top.
Unlike cement, if you've made too much and don't use it all, stick it in a container and add an inch or two of water to cover it. It will keep forever.
:lol: :lol: :lol:I'm your wife first and your labourer second!
plasticpigeon said:I know this is a really geeky question but are all the bricks in your walls headers??
jackpoint said:We must admit it's a bit of a tough choice on the render/brick but we thought we would start by taking it all off and see what it looks like. If there's a big patch of bad brickwork hidden somewhere I guess that will make our minds up for us.
Cheers all![]()
