Flyfisher
- Norfolk, UK
Feltwell said:To make matters worse, I actually rebuilt the section late last night - very late. On soldering it though it seemed that the solder just didn't take - I have a decent propane gas torch, but with 22mm pipe it just didn't seem to be getting it hot enough for it to solder properly. On refilling it leaked worse than ever![]()
So, this morning, a trip to the local plumbers merchants relieved me of £50 for a MAP torch - propane on steroids would be the best description!
I use an old 'camping gaz' type blow torch and I've never had a problem with soldering 22mm pipe (probably shouldn't have tempted fate there) so I wonder if heat really was the problem or just dirt/grease messing up the flow of solder? Still, you've fixed the problem for a paltry £50 (paltry in comparision with no heating!) and got a new toy into the bargain - so not all bad then.
