Zebra
- St Albans, Hertfordshire
Good grump, Doug. None of us can have any helpful suggestions to get around that one...
...particularly those of us with the same problem.Zebra said:Good grump, Doug. None of us can have any helpful suggestions to get around that one...
xanthe said:On the insurance stuff...
Talked to a specialist insurance company the other day for Listed Buildings - who we are going with as their deal was significantly better (and cheaper) and they didn't get stressed when I said that yes, the house had had movement in the past 400 years - and frankly timber-framed buildings are built to move and there is something wrong if they haven't moved.
Discussing rebuild prices, he recommended that for listed buildings you should calculate at around £2.5k for each square foot of building and then round up to the nearest £50k. Apparently for new build it's more like £1.5k for each square foot and you can also alter things a bit if you have very large rooms - a sq ft in the middle of a room is a lot cheaper than a sq ft at the edge that has walls and windows attached to it.
The calculation for ours was almost exactly the same as our purchase price. I could pay for a proper valuation, but I'd rather add a bit extra to the insurance premium for more cover. As a specialist insurer, they allow for conservation builders and following the COs plans not trying to do everything on the cheap with Bob the Builder round the corner.
Don't know if that is helpful to anyone.
Flyfisher said:As for CliffordPope's suggestion of just buying insurance 'up to £2m' well, yes, that would probably work - if it was affordable by the home owner.
CliffordPope said:Flyfisher said:As for CliffordPope's suggestion of just buying insurance 'up to £2m' well, yes, that would probably work - if it was affordable by the home owner.
Lots of insurers do that, recognising the difficulty of estimating rebuilding costs. It doesn't necessariuly cost any more. I halved my premium when i changed company and went to one with this kind of open-ended value.
The analogy with life insurance would be valid if you were say an actress insuring only your legs. But with a house you are expecting the company to cover the risk of all or any portion of the house being damaged.
You could perhaps insure only the downstairs, or just the roof, and then your argument would apply. But you would be uninsured for other portions of the house.
Or you could omit flood cover.
But in general a £1m house represents twice the risk of a £500,000 house. By only insuring for £500,000 you are trying to get your insurance at half-price, so obviously as you are underinsured they halve any claim you make.
Surely you, of all people, should be familiar with Murphy's Law.DJH said:why do leaks mainly happen in the most inaccessible places and invariably behind/underneath finished surfaces.
Murphy said:Whatever can go wrong will go wrong.
Penners said:Murphy was an optimist.
DJH said:Grump...plumbing. Why is it that the Republic of Ireland still use imperial size pipes and fittings :twisted: meaning that all the metric valves,fittings, clips. inserts, olives etc that I brought over from the UK are useless here. Grrr.
