LadyArowana said:Zebra said:I don't understand. Under what way are you penalised for being under-insured, other than the risk outlined above, of your payout turning out to be insufficient for your rebuild costs?
I believe that they won't pay out the total amount insured in some circumstances, just a %, so if you are 1/2 under then they give you 1/2 ? Not totally sure
Yes, that is exactly how it works.
So, my house is insured for up to £500,000 rebuilding costs. If it got completely destroyed and then actually cost £1,000,000 to rebuild, the insurance company would say that I was under insured by a half and so would only pay half of the £500,000 policy limit, meaning I only get £250,000 even though I've always been paying a premium to cover £500,000.
The above is just morally wrong as far as I can see, but at least it is clear and very unlikely to actually be a problem. That is because if my house was totally destroyed, with absolutely none of its original features left, then I could easily build a modern 5 bedroom oak framed house to replace it for £500,000 and even have money left over. But, if just half of the house was destroyed or damaged, then the local CO would rightly be involved in deciding how the repairs and replacement should be styled and built. Depending on what decisions are made, it could then work out to cost £500,000 to rebuild just half of the house. In that case, with half a house costing the full policy limit to rebuild, will the insurance company say that I was under insured by a half and reduce my payment? Well, the answer is probably yes they will. I have phoned them and spoken to the most senior person I could eventually get transferred to, and although it was wrapped up in loads of caveats and waffle, that does seem to be the approach that they would take in that situation :evil:
Flyfisher, thank you for the link, but the trouble with all the online rebuild calculators seems to be that they specifically exclude buildings that are listed or of non-standard construction. On this particular one though, I was surprised to also read the following statement containing the bit I've underlined which is wrong! "A second option is to use a rebuild calculator. Though simple and free to use, the drawback here is that you only get a rough idea of your home’s rebuild cost. This is important to bear in mind because if you underinsure and then, for whatever reason, your home requires a rebuild, you would only be paid up to the amount insured for, leaving you to cover any shortfall."
