Greg.Hobson
Right chaps, I've got nearly 40 pages in the catalogue so far and, despite your help FF with the header/footer, all my pages are coming up numbered No.1 not 2,4,4 etc.
I'm using Windows 7 which has icons on the top of the screen to click but I can't find anything about sequential numbering.
Whilst my IT skills were last put to professional use over 10 years ago (and my degree in Computer Science now over 35 years old!), I remember having the same problems when learning this particular element and so can relate to your problems. Regarding the numbering, it used to be the case that you set up only the first page and whatever you set up on that page carries forward (as long as you set the right parameter in that page). Any amendment to any following header/footer effectively resets the header/footer from that page onwards. If you have, for instance, copied the header/footer to subsequent pages then it won't work. It took me many, many documents to learn this simple rule.
Regarding the index, it used to be the case that you have to identify what is to appear in the index (or contents or appendices, etc) by labelling them as such (a long and painstaking exercise) and then getting the program to create the finished table in the place where you want it. Since I still use Word 2000, all I can tell you is that indexing appears in the "insert" menu under "Index and Tables".
I am a little confused however, since I had assumed that what you were creating was an index on your PC to the physical books. To find what you want on your PC, why not just open the file and "Search"?
Greg
