Lime
- East of England
Ian Bond said:I have a reply to my questions from Second Nature. They replied within 2 hours.
Good Morning Ian,
Thanks for your email.There are some interesting clauses in BBA certificates, but, unfortunately, the BBA does not consider 'alternative' constructions like yours. Yours is a fairly standard refurb application where account has to be taken of the nature of the existing system and the age of the components where moisture accessability has been provided over many years. As you rightly say to reduce that facility would be to affect the moisture content levels of the fabric and lead to possible deterioration.I am sure that the system as you envisage, ie without a' control' layer will perform as intended and that there is sufficient breathability to accomodate moisture migration out of the system. The ventilation space you intent to use above the insulation and beneath the breather membrane will ensure that adequate air movement takes place and so minimise any condensation risk.
Ok. He's saying that he thinks you can get away with it.
I could accept that.
But then he says this:
The BBA Certification is sometimes contradictory as, no doubt, the certificate for the breather membrane will indicate that it can be used without a 50mm ventilation cavity.(eg Tyvek Supro, Klober Permo Forte, etc.) Many projects like yours have been successfully completed without any air gaps and give no cause for concern. I hope this is of help. Best regards
Paul Pickett
Technical Consultant
Second Nature UK Ltd
That comment alerted me so I had a look and found this:
Agrément Certificate No 94/3054 said:5.2 The product may be treated as a vapour
permeable underlay when considering ventilation
of the roof space, and may be laid directly over
the insulation without ventilated air space
provided the passage of moisture through the rest
of the roof structure is controlled, and the system is
convection tight.
I call that bending the truth and I'm being polite.
