Nemesis
- Planet Earth
Well, I wonder if in order to get it all has to comply with the latest building regs?
If in doubt, give them a bell.
Brochure said:To retain the benefits of water
vapour absorption and release,
THERMAFLEECE should be
used in conjunction with a
vapour permeable breather
membrane.
Certificate said:The batts are used in conjunction
with a vapour-permeable roof tile underlay, treatedtimber
counter battens and tiling battens in tiled or slated
pitched roofs designed and constructed in accordance
with the relevant clauses of BS 5534-1 : 1997 for
dwellings
Which makes it very clear that a vapour barrier of some sort must be used with Thermafleece on the warmer side too.7.5 A vapour control layer should be provided to the
warm side of the product.
andData from smoulder tests indicated that the product
is non-combustible as defined in BS 5803-4 : 1985.
Smouldering was found to continue a distance of
70 mm for up to 17 minutes.
When installed with an internal lining board, the
insulation will be contained between the roof and
internal lining board until one is destroyed. Therefore, the
insulation will not contribute to the development stages
of a fire or present a smoke or toxic hazard.
sounds rather like a standard sentence that gets put in all situations where insulation is involved in the modern non-breathing, put-trickle-vents-in-your-window-frame type of build. It is not appropriate advice for what we are discussing here.7.5 A vapour control layer should be provided to the
biffvernon said:You may be asking for trouble, NT, but Ian won't get any if he leaves out the vapour barrier.
The BBA line:
MdB said:Rockwool is around £10 per square metre for 300mm thick so £3000 would get you 300 square metres which is about 4 times the size of my 4 bed house. Either you own a mansion or that price is a little excessive. Did it include installation?
