Penners
- Suffolk, England
The benefit of having a youthful husband, perhaps?Moo said:Gerroff, Penners. She doesn't look a day over 40.
Having seen pictures of your chateau, I would say about 18 months!!GK said:I wonder how many years it will take me to recoup well over £5000 in fuel savings?
skier-hughes said:GK in your searches for pellet boilers, did you ever come across any boilers that could take larger sized pieces of wood?
skier-hughes said:NT,
I'd never seen the atlantic heaters before, it just happened I opened the mag as I was reading the forum, are they no good?
My gas is nearly as expensive as my 10 hour cheap rate electricity.NT said:skier-hughes said:NT,
They're just electric heaters, like any other electric heater. With added marketing blurb. And any resistance heater is going to cost a pretty penny to heat a house with.
Non-storage electric heaters are simply the most expensive type of heating possible, and are not worth installing even if given them free.
There seems to be a series of attempts to re-market the simple old resistance heater to make it appear desirable. The oil filled radiator is perhaps the oldest of these, then there were ceramic heaters, now these... theyre all just electric heaters with the same 100% efficiency and the same very high run costs.
NT
My cheap rate electricity costs 4.75p per kilowatt hour whereas my gas costs 2.83p per kilowatt hour.NT said:Electric heat to water is 100% efficient, but the electricity unit cost is high.
That's an interesting observation, NT.NT said:Electric heat to water is 100% efficientNT
NT said:Efficiencies for boilers are listed on a sedbuk site, lets see...
http://www.sedbuk.com/
NT
assuming 30p/litre for oil
You've correctly described my cylinder. It's about 5ft high (can't remember its capacity), so the primary coil is lower than the reach of the immersion heater. This means that the immersion only heats about the top 60% of the cylinder, while the coil does the whole thing.Me said:Also, Penners, please do let me know the outcome of your experiment, but I have a couple of thoughts.
Firstly, if your cylinder is like mine then the heating coil is lower down than the immersion heater, so if I have both on like you did last winter then the immersion will only come on if I use a lot of hot water during a boiler 'off' period. Is this the same with yours?
Secondly, are you keeping a record of the winter external temperatures over the two years? I would have thought that the differences between a cold and a mild winter would have a big impact on your oil usage and confuse any figures you are getting from your immersion heater use?
