Feltwell
- Shropshire, England
We have code 8 lead in use here right now. Also known as 'kin heavy!
Keithj said:but the fact that he kept it must be significant.
Feltwell said:We have code 8 lead in use here right now. Also known as 'kin heavy!
Feltwell said:He may have had no use for it whatsoever, and no idea what it was. But it might come in useful one day.
A similar device was (is still?) used for listening to the inner goings-on of engines, back in the days when big ends, small ends, crankshaft journals and suchlike used to wear out and be replaced with monotonous regularity.Keithj said:s a stethoscope for listening to water pipes to hear if there was a leak. It worked, too! Imagine a long rod in a tube, with a spike at one end and the diaphragm of an earphone at the other.
Penners said:A similar device was (is still?) used for listening to the inner goings-on of engines, back in the days when big ends, small ends, crankshaft journals and suchlike used to wear out be replaced with monotonous regularity.Keithj said:s a stethoscope for listening to water pipes to hear if there was a leak. It worked, too! Imagine a long rod in a tube, with a spike at one end and the diaphragm of an earphone at the other.
Then you were undoubtedly listening to the diesel pump of a Fordson tractor engine on tickover. The most pleasingly musical of mechanical sounds.atticman said:All I could ever hear was tapocka, tapocka, tapocka........
My money is on it being a Bolinder Munktell Swedish tractor - possibly a T25. BM were later bought out by Volvo and became the company's construction machinery division, called BM Volvo, later Volvo BM, later (and now) Volvo Construction Equipment.Flyfisher said:Not sure what sort of tractor this is
It's worth adding that FF is being very understated about Mrs FF's considerable achievements in that field (er... lake).Flyfisher said:Mrs FF who spent a number of her younger years burning up gallons of the stuff (mixed with methanol).
Flyfisher said:Really? I find gear oil (I'm thinking EP90) pretty bad for the nose. Something to do with all the sulphurous additives I believe.
