DJH
- Co Tipperary Ireland
Ha ha. Love it...
Anyway Dick van Dyke would call it a development plate. It's used in conjunction with a pair of dividers to mark a lead pipe prior to soldering a branch into it. I've taken some action photos to try and illustrate how it was used...
The lead pipe is coated in plumber's black (also known as smudge or soil) which prevents excess solder from running onto and sticking to parts of the pipe where you don't want it.
I've used a piece of plastic waste pipe just as an example and marked it with marker pen as if it was the blacking. Depending on the diameter of the the pipe that is going to have the branch put on it and the size of the branch pipe, the relevant hole is selected in the development plate and a line is scribed using one point of the dividers onto the blackened pipe. The area of blacking within this line is scraped back to clean lead and the new branch is placed in the hole of the main pipe and is connected on to it with a wiped solder joint.
Doug
Doug
