JoceAndChris
- Lincolnshire
Oh, God, you can really see why people go for plastic can't you? Glad you're getting somewhere with it though.
I don't completely follow your question, but you can see from the shape of my house that I don't have long 10m runs.
Because the house is composed of so many protrusions and hexagons the guttering has been cut to follow its shape, meaning there are joins on each corner, which is neat and actually poses no problem with drips. (though I do know that welding the lead guttering at weak points was a yearly job) The longest section is 3.80 metres. One plank sits flat against the wall. The plank which supports the lead gutter on top of it appears to be a separate plank. Stuck onto it, which you can just about see in the first pic I posted, are evenly spaced squares of wood, a kind of moulding, which, according to Gareth Hughes, are called mutules.
I think it's quite different to what you had in mind. Good luck!
johnandrew said:JoceAndChris: Is your guttering machined from a solid chunk or made from planks? How long is the longest section?
