andrew gayton
Wow. Those pots are m a s s i v e ................... The wind loading on that sort of surface area would certainly be enough to loosen them over time - bearing in mind that the base of the pots only rest on a minimal surface area [of stack or slate/metal packing] before being flaunched up (and look at the volume of flaunching that has been used [the builder knew that there would be trouble ahead :wink: ]) - so anything you can do to minimise that would only be for the good. I assume that the pots are that tall because of down draught / draw problems? is there scope to raise the stack brickwork to help reduce the size of the pots, or do you wish to retain the existing pots?
Without going into massive detail, there is an act from 1996 (although it might be 2006) which allows you as a property owner the right to maintain your property. I think that you might well have been able to serve a notice of sorts on the highways dept. basically informing them of what you intended to do before actually doing the works - this *might* question the whole issue of permission being required from them - I might have to check that in more detail.
Also, if dangerous structures issues couldnt be made applicable by B.C, then I am sure that the H.S.E would be interested..............
it must have been completely frustrating getting this sorted out.
