biffvernon
- Lincolnshire
Cat 5 is a very small cat that can fit down mouse holes. Handy, eh?
Read the whole article here.Kevin McCloud in today's Torygraph said:I'm not saying we should all live in glass boxes, nor that we should incorporate all that macho, category-five-future-proofing-cable gizmo stuff, such as mood dimmer systems and remote-controlled electric window blinds connected to your own satellite weather station. People think of that as being so very up to the minute, but of course it'll all go wrong in a year's time and date very quickly.
Nemesis said:And as for snooping on who is using the bog... I think that man needs help
NT said:It wont be long before standard CH systems have a temp sensor in each room, all wired back to the control box, and heat is at times delivered on a per room basis to achieve 3 things:
1. avoid any rooms being heated to above set temp
2. use different timing schedules for different rooms
3. and maybe enable whole house fan cooling, eliminating ac use
biffvernon said:NT said:It wont be long before standard CH systems have a temp sensor in each room, all wired back to the control box, and heat is at times delivered on a per room basis to achieve 3 things:
I can't see much point in heating a room that you don't use. And when you do use a room then you are in it so don't need a sensor and wires and control boxes. You just light the fire and put another log on or twiddle the tap on the radiator if you've got central heating.
Whole house fan cooling? Why not open the window, doh?
Spot on, Lime!Lime said:you can predict with almost absolute certainty that the cable will be in the wrong position and the wrong type for any unforeseen/future use.
