Penners
- Suffolk, England
"Difficult" is a very subjective concept. One is forced to fall back on the old adage, "it's easy when you know how".SD said:Is it really difficult to fit windows. Could we do a DIY job?
Provided the windows have been carefully specified, so that they are a good fit in the window reveals, then fitting them is not a difficult job, assuming you have a reasonable basic level of competence at woodwork and building.
"Carefully specified" means that the window should be a good, comfortable fit in the reveal - not too big and not too small. When you come to measure up the reveal in order to decide the overall size of your window, for goodness sake don't assume that it's square - or rather, that every corner is a right-angle. Measure the height, measure the width, and then measure the diagonals. If they aren't identical, then you have an out-of-square reveal, and this will affect the size of window that can be fitted.
Some people like to play it safe and specify the window a bit smaller than the reveal, then secure it in place with wedges before finally fixing it. (Hence Biff's comment above). This also makes it easier to get the window truly plumb if the reveal is a bit out-of-plumb. Personally, I tend to let the window follow the line of the reveal, even if it's a bit out-of-level. I think it looks better.
Once you've got a frame that fits nicely into the reveal (with or without wedges - your choice), then modern frame-fixing screws make the job of fixing pretty straightforward. You can drill through the frame and into the masonry (I assume your house is masonry?) with the same diameter drills. Countersink the holes in the frame then just drive in your frame fixings with a hammer. Don't be over-enthusiastic at this - one bad hammer blow can cause damage to the frame and/or bend the screw. Just bang away moderately and patiently until your screw and its sleeve are both below the surface level of the frame (you'll probably need to use a drift or punch for the last few millimetres below the wood surface). Then give the screw a little tweak with a screwdriver - usually about half a turn. You can then fill the countersink to hide the hole, then sand off flush with the wood.
Your choice of frame sealant, to fill any gaps between the frame and the masonry, is up to you. You can use a modern cartridge mastic product, or you can use Biff Vernon's favourite traditional recipe of fine sand and linseed oil, mixed to a paste.
Just one final word of warning. Be careful when you're driving in your fixings that you don't wrench the frame out-of-square. This will make the opening sashes jam.
I hope that helps you to decide whether you regard the job as easy or not!
