paulb33
- Penarth, Vale of Glamorgan
plasticpigeon said:What a find! I thought it would be roughcast, I think that would look better than flat. Looks like perhaps your windows were white as well!!! I can't comment much on the render as I really don't know enough. Logically I'd have thought that if the bricks are hard and vitrified and the mortar used is cement, then cement render would be ok. If the bricks are softer and more porous and the mortar used is lime, then lime would be better as water that may get in through small cracks in the render will be able to evaporate out through the render.
Just seeing this thread and may have missed something relevant. But, why do you want to use lime? It probably was an early cement render. Our 1901 is grade II listed with cement render. No particular advantages to lime for your house - only aesthetic and perhaps flexibility on movement?
The render is a key element in these Edwardian buildings. Sadly, inappropriate repairs and painting do so much to harm the aesthetic of these interesting buildings. That and uPVC has done so much to discredit this period of architecture. On this subject, there's an article here you might find interesting:
http://www.buildingconservation.com/articles/pebbledash/pebbledash.htm
Oh, I was also surprised to find that our walls were cavity. The survey said solid. It was only when I drilled a hole and tried (failed) to feed through a TV aerial cable that I discovered the double skin. I was forced to get a much longer drill bit.... :shock:
Very interested to read your updates. We have a similar journey to make with our render repairs and uPVC replacement.
