Penners
- Suffolk, England
As has already been said (25 times or so!) Henry's yer man.
Flyfisher said:With the cleaner outside on the scaffolding and allowing the wind to blow the fine dust away across the fields I was able to very quickly clean large areas of roofspace without any clogging problems.
benmc said:Earlex Combivac WD1000 230V
http://www.screwfix.com/prods/23140/Cleaning/Workshop-Vacuums/Earlex-Combivac-WD1000-230V
£50
Currently using one on our rennovation and it is very good
Ben
George was a mad German, while Henry was a syphillitic megalomaniac.plumbers mate said:What's the difference (apart from the name) between a George and an Henry?
shelli said:benmc said:Earlex Combivac WD1000 230V
£50
Ben
How much are you working it though?
the model you describe has got those pleated paper filters as well - like the K'archer workshop one - and a similar price - they're rubbish when they get filled with dust -so after you've used it for 2 minutes you must stop and empty dust from filter - the drum will still be almost empty - put the whole thing back together again and watch in mute horror when you switch it back on and it blows clouds of dust out of the drum edges -
I would advise the OP to pay up to his max budget and get a henry or VAX
