andrew gayton said:using old timber will encourage robbing out and the loss of buildings due to the non-salvo members of the reclaim industry.
Ian Bond said:Listed buildings ...
About 10 degrees larboard, wouldn't you say, Mr Penrose?
Couldn't say. But if it had a chimney to stabilise it, I wonder whether it would have gone walkabout quite so much?biffvernon said:Why hasn't that house got a chimney?
I would say diamond mullions without doubt. I reckon the trickle vent's (qv) been blocked up, though.biffvernon said:I wonder if the three thin vertical timbers above right of the left front door are the mullions of the original window.
There is, of course, a third option, and that is to have some new bricks handmade that match the old ones.Pford75 said:If I had to replaced some badly spalled bricks, would it be better to use modern, machine-made brick which will spoil the elevation or use reclaimed brick which is 'messing with the historians'?
middi said:......it calls for every brick to have initials and date scratched on their surface :wink:
Penners said:There is, of course, a third option, and that is to have some new bricks handmade that match the old ones.
Moo said:Cheap as chips.
Ian Bond said:a bit battered.
