Penners
- Suffolk, England
But not always...!LadyArowana said:they also say "be careful what you wish for", because it is usually disappointing
LadyArowana said:They say a picture is worth a thousand words........
You are a Gentleman Penners, I aint no lady!Penners said:Ooooooooh, Joss! If I'd said that, you'd have told me off!!!
Penners said:Joce - I don't know whether you;ve had a chance to explore the website that I linked to in my last post, but this could be quite interesting:
http://www.bishopsbeds.co.uk/shop_products/view/value-slatted-frame
They offer fully made-up slat sets made-to-measure. The above is the cheaper one. So all we'd have to do is work out how to mount the slat set on your bed-frames.
The photos I requested should help us plan that.
I'm not quite sure I understand that. The critical dimension is (with the bed assembled) the width measurement from the inside face of one siderail to ditto on the other siderail. Is that what you've measured?JoceAndChris said:The width from side to side excluding what the rails take up is 91 cm
Yes, my above suggestions assume that you have ensured a happy marriage between the original siderails and the head- and footboards. Judging from one of your original photos at the top of the thread, you have the iron dovetail brackets to re-attach to the head-and footboards in place of the projecting iron brackets. You should then find that the dovetail grooves on the original siderails will simply slide down vertically on to these brackets.JoceAndChris said:The original brackets for the satinwood side rails have been supplied, it's like a projection on the rails and a groove on the bracket. There would need to be some unscrewing of the new cast iron brackets, filling and reattaching the originals but it looks feasible.
I also agree with Lime's theory. But I'm afraid I wouldn't do as Moo suggests. Authenticity is all very well, but those metal-framed sprung bedsteads (whether mesh, coil spring or both) were abandoned for a reason. They are (as you suspect, Joce) expensive to make and they tend to go saggy in the middle, which isn't comfortable or good for the back (have I mentioned that I have a bad back?).JoceAndChris said:I think Lime's onto something there, that sounds very likely to me.
I'll get a quote from my lovely local blacksmith, but I fear it will be a good deal more costly than Mr P's idea.
Penners said:...but I haven't seen a Vono bed for about 20 years.
Beggin' yer pardon, Milady, but I now know that I've seen one photo of a Vono bed in the last 20 years. However - just to set His Lordship's mind at rest - I've never been in your bedroom and seen said item in the flesh.LadyArowana said:Penners said:...but I haven't seen a Vono bed for about 20 years.
That isn't quite true Mr P
Ah, be a bit careful with that combination, Joce. Pocket spring mattresses should only be used on slatted bases when the slats are very close together. The essence of the pocket spring design is that each spring can work independently of its neighbours, so if the gap between the slats is greater than the diameter of the springs, after a while you can get some springs pushing down in between the slats.JoceAndChris said:I find the combination of the bouncy wooden slats and a good pocket sprung mattress ( not hard) on our king size bed really excellent for my back.
"Keeping a close eye" is another way of saying "I'll wait and see whether the horse bolts - if it does I'll close the stable door"!JoceAndChris said:I never knew that about springs and slats- I'll keep a close eye on our main bed in that case!
