DJH
- Co Tipperary Ireland
That's a neat installation MdB. Will those connectors be accessible at all in case you need to get at them at anytime?
Doug
Doug
The coils and connectors have been tested to 6 bar (or thereabouts) and have been operational for the last few days at 3 bar with no leaks shown. The plan then is to cover the connectors before the screed is put down so that they will be easy to expose if ever there is a leak. It will be in the middle of the floor so a hatch or similar won't really be a good idea and it will be easy enough to dig up if we do have a problem. The cover will also allow a bit of movement between the old and new screed without hopefully damaging the pipes.DJH said:That's a neat installation MdB. Will those connectors be accessible at all in case you need to get at them at anytime?
Doug
Apart from putting the pipes down, I haven't done much recently. Our builders have also disappeared giving silly excuses like "my wife has just given birth" and "it is too cold outside to put render on". These days you just don't seem able to get the staff :roll:Zebra said:MdB, stop making such progress at once, you're putting the rest of us to shame.
In their defence, they did start on the 10m^2 around the corner that isn't visible from the camera.vicky whitworth said:Not much happened before the first tea break through but once the kit kats kicked in...
