So in phase 1 of the house renovation we rebuilt a couple of walls, replaced a lot of cement with lime and basically made the house sort of habitable. It only took us 4 years and the kitchen is still a mess....
Time to start Phase 2 where we plan to add an extension and insulate the back of the house.
The first job was to remove the asbestos cement roof from the garage so we can get proper access to the end wall. It is in a poor state and the chimney needs to be rebuilt to allow the open fire to work again. Removing the roof turned out to be not too difficult (apart from the bunny suit) but double bagging the asbestos sheets was a pain. That job is done now though so tomorrow, the render will be coming off to see what state the stone is underneath. Internally this wall was in poor state and took a months worth of evenings to repair. It will be interesting to see what we find on the outside. To rebuild the chimney, it needs to be completely opened up and the old liner removed which will be fun. It is currently filled with lose fill - especially at the top - and this is causing the wall to bow outwards as the fill drops over time. Currently there is quite a big crack running down the outside of the render following the line of the chimney.
The crack in the render is just visible in this picture. It is worse close up.
As part of Phase 2, the garage is going to be replaced by part of the extension which will be made using modern construction methods. This causes issues were it meets the old wall. There is such a high water table around the building that moisture rising up the old stone work is going to be a major issue to deal with. Something like 5 years ago, I dug a trench next to the wall inside the garage to bring down the ground level to a bit below internal floor level. This certainly helped with damp but it definitely didn't sort it completely - the water table is just too high. Often, we find the bottom of the hole to be full of water that has migrated in through the soil.
No water in the hole today but you can see that the side walls are still damp to a high level.
The plan is to replace the dirt floor with an insulated concrete floor with underfloor heating built in - the same as the rest of the house. To help contain the moisture levels, drainage pipes will be included underneath the floor to help keep the ground water levels low. We will also leave a strip next to the old wall which will be filled with limecrete to increase the area of evaporation and to reduce the amount of digging needed next to the old wall. Hopefully this ideas will be enough to contain the damp. Only time will tell.
