wobs
- Hull - there's a nip in the air.
From my days in engineering, I recall cutting metal with a slitting wheel by hand. A 6" wheel, and it can shatter without warning, but cut just about anything.
A 24mm version would do a 2" hole if you can get in there with a Dremel type tool.
http://www.tooled-up.com/product/dremel-409-24mm-0.64mm-thick-emery-x-36/121661/?Referrer=googleproductlisting&gclid=CNKJzvv_zr4CFRQctAod2AEAWw
There were other tools that were hand held, but I suspect you won't have access to them:
Oxy-acetylene - could be a bit over kill, and risk damage to boards.
Pneumatic drill - unlikely to have access to such a dynamic heavy duty tool, but we used them to clean up castings and enable repairs to casting faults. Could be powerful enough with the right attachment.
