philpjuk100
- newark nottinghamshire
Grandson Dean with my current car,maybe his first car!. SWING IT DEAN!.
- or when your keys were on their way to Spain in a boyfriend's luggage.Penners said:you could gain entry into the car via the boot ... when you'd locked your keys inside.
tobydog said:In those days gone by the mechanicals were solid and the body work short lived but these days it seems to be the other way round. More things to go wrong and way too many compromises to comply with legislation. I have an Audi A3 now but I've had more parts replaced on this car than any of my others.
Flyfisher said:......tobydog said:In those days gone by the mechanicals were solid and the body work short lived but these days it seems to be the other way round. More things to go wrong and way too many compromises to comply with legislation. I have an Audi A3 now but I've had more parts replaced on this car than any of my others.
But when something does go wrong it's no longer possible to get it fixed by the local blacksmith and even a main dealer can only swap out the broken part and, increasingly an entire subsystem, at vast expense compared to the actual faulty component........
I checked on the web and found it was a common problem...... A quick check on the web and I bought two replacements for £6.50 each. I replaced the batteries, refitted the sounder unit and all was well.
A sign of our disposable times I suppose.![]()
...but that did have its drawbacks.Moo said:it was possible to blank off reverse gear...
I quite agree, FF. When I think back to my early days of car ownership, there was barely a week went by without the car needing some sort of attention. An engine lasted 50,000 miles (if you were lucky) before it needed to be stripped down, rebored, the crankshaft reground and so on. The bodywork constantly needed to be attended to with Kingston Kurust, or some such potion, and then resprayed with an aerosol can. Door seals leaked, electrical connections corroded, choke cables broke, the timing or mixture went awry... it was endless. Services intervals were usually 3000 miles!Flyfisher said:I think it's fair to say that modern cars are engineering masterpieces
Keithj said:There's a lot of new stuff coming in the way of automotive regulations.
My little toy has a fault in the ECU that says the engine isn't feeling well. The local bloke's computer tells him that there's nothing wrong with the engine but that that the ECU thinks there is, and is not going to change its Japanese mind in a hurry. No problem - it's legal to drive and will pass any emissions etc test (just did).
However, from next autumn any fault in the warning lights (such as not lighting to test on startup, or staying on when they shouldn't) is an automatic MOT fail.
A new ECU, with fitting, is just short of £1,000 at a main dealer. Sometime this summer I'll visit a man I know...
Meanwhile, here's my first car (with the wrong wheels on!):
plasticpigeon said:Almost everyone I know who has had an Audi has had a whole host of parts replaced
tobydog said:Keith - you may be okay. If the warning light is only associated with the engine management, and the car passes the emissions test, I don't believe this is a reason for failure. The MOT police appear to be looking for warning lights related to safety features / driver aids like the Electronic Stability Control / Programme, ABS, etc). I would be keen to know if anyone has heard differently.
