DJH
- Co Tipperary Ireland
of course deer... 8)
FF - do sinks and baths count as "foul" drainage? I'm pretty sure you're correct that hoppers are not permissable for lavatory outflows, but I've never been sure whether grey water is regarded as foul or not.Flyfisher said:I'm sure I've read somewhere that hoppers for foul drainage (e.g. Sinks, baths, etc) are not allowed by current building regs.
Penners said:FF - do sinks and baths count as "foul" drainage? I'm pretty sure you're correct that hoppers are not permissable for lavatory outflows, but I've never been sure whether grey water is regarded as foul or not.Flyfisher said:I'm sure I've read somewhere that hoppers for foul drainage (e.g. Sinks, baths, etc) are not allowed by current building regs.
malcolm said:I've had a good read through part H. They like to see a trap so you don't smell the sewer but it still seems OK to use hoppers for kirchen and other less smelly waste.
Unless I have misread. If current regs were applied to my drainage it would fail - not enough slope. Hopefully building regs will be content if it works.
Me too. I reckon I'm about an inch shorter than I was 10 years ago.malcolm said:I have less height than I thought.
You'd need to check this with your building inspector, but although 1 in 40 is regarded as the optimum I believe the regs allow between 1 in 10 and 1 in 80 for 100mm underground soil pipe, so you might be able to reduce your slope a bit - if that's any help.malcolm said:a 1 in 40 slope
Quite so, Doug. I was taught that the range I mentioned above allows the solids to be carried along by the liquids. Any steeper incline and liquids flow too fast, leaving the solids behind. Any shallower and the flow of liquid isn't enough to carry the solids along.DJH said:I was taught that a fall 'should allow a self cleansing velocity'.
DJH said:In my experience water trapped gulleys can be a maintenance nightmare especially if a waste disposal unit is connected to it as sludge builds up in the trap and grease will congeal quickly because of the cold water in the trap In fact that's true of any trapped gulley used by a kitchen sink only. It's a smelly job to clear a blocked trap...been there and done it...![]()
I reckon the law probably regards the contents of the trap as your neighbours' property, rather than yours. So I do hope that you do your legal duty and return it to them.Feltwell said:I've ended up cleaning out a trap that services a neighbour's kitchen sink a few times, it's on my land but only serves their kitchen
