Keithj said:Tell them they have one last chance to fix it, or you will consider that they have broken the contract.
Then go to a better ISP.
I dont want to go with Talk Talk anyway Keith, I've heard too many bad things about them.
Keithj said:....
you're using BT kit regardless. It then comes down to how good your particular ISP is at getting BT (and Openreach, which is a different fish) to sort problems. PlusNet don't do badly.
AMc, that's exactly the situation where we are - no unbundled local loop. How does one get that changed? If I understand it correctly, it's a monopoly situation, so how can it be allowed to persist?AMc said:If you're in the sticks and your exchange hasn't been "unbundled" then you're basically choosing between ISPs reselling a BT wholesale connection product.
BT are forced by OFCOM to charge more in exchanges with no competition. The idea is that it makes it more attractive to other companies to put their kit in the exchange. Where there are other companies, they are allowed to charge less.Penners said:AMc, that's exactly the situation where we are - no unbundled local loop. How does one get that changed? If I understand it correctly, it's a monopoly situation, so how can it be allowed to persist?
What hardware upgrades? My understand is that all of the 512kbps kit was capable of 8Mb when installed. It was artificially limited to 512kbps in firmware so that it was more likely to work initially and then kept that way for marketing reasons and because of limitations in the back haul. To upgrade, all they had to do was change the firmware, likely remotely, at zero cost. The more recent kit is also capable of 24Mb bit but a lot (like my exchange) is kept at 8Mb. The LLU operators on the other hand went straight to 24Mb.AMc said:because BT are able to charge more where there is no competition in the exchange I think it probably helped to improve the overall spread of ADSL (512kbps) and then ADSL Max (upto 8mbps) because they knew they could recoup the cost of the hardware upgrades as the unbundling was unlikely to be profitable in the lifetime of the equipment.
Follow up: http://www.theregister.co.uk/2011/08/01/bye_bye_bt/AMc said:Here is a story of one man's lone battle to get any broadband at all which makes for entertaining reading.
http://www.theregister.co.uk/2010/12/03/not_spot_diary/
I could tell you all about that, if I weren't so reluctant to talk about it.MdB said:because of limitations in the back haul.
I was manly referring to installing ADSL equipment at all in areas with small numbers of lines and long distances.MdB said:What hardware upgrades? My understand is that all of the 512kbps kit was capable of 8Mb when installed. It was artificially limited to 512kbps in firmware so that it was more likely to work initially and then kept that way for marketing reasons and because of limitations in the back haul. To upgrade, all they had to do was change the firmware, likely remotely, at zero cost. The more recent kit is also capable of 24Mb bit but a lot (like my exchange) is kept at 8Mb. The LLU operators on the other hand went straight to 24Mb.AMc said:because BT are able to charge more where there is no competition in the exchange I think it probably helped to improve the overall spread of ADSL (512kbps) and then ADSL Max (upto 8mbps) because they knew they could recoup the cost of the hardware upgrades as the unbundling was unlikely to be profitable in the lifetime of the equipment.
