briany
- Waterford, Ireland
As I said, I omitted the heat leak rads & open vent to expansion tank - from the diagram, not the system!
I've also got pressure relief valves on the outputs from both appliances. The central heating loop will be isolated from the heating appliances in the event of a power outage - no more hot water into that loop. The appliance loops can drive water through the gravity circuit incorporating heat leak rads, venting into the attic expansion tank if necessary, and pressure relief valves as a failsafe.
