Aidan
- Essex/London
http://www.cmxciphexshow.com/docs/CMX_CIPHEX-wood_solar.pdf
I haven't read all this, but the first diagram shows the central heating and DHW storage cylinder arranged as secondary circuits, with the primary circuit being from either the boiler or the solar heated thermal store. I don't believe solar space heating is effective in the UK, though it may be fine in Arizona. The diagram on page 4 shows the wood fired boiler linked through a plate heat exchanger; the arrangement shown wouldn't be legal in the UK since it would stop dissipating heat in the event of a power or control failure. The gravity circulation heat dump and open vent could be added quite easily. Also all the primary flow passes through the gas-fired boiler so this assumes it has a flue damper or fanned flue, to stop it dumping heat to atmosphere if the wood fired boiler is providing the heat.
I'm don't think that a thermal store has any advantage if you are using a condensing boiler.
