Lime said:I think there is a very strong argument to ensure that the hot and cold supply to the bathroom are electrically connected to each other if nothing else, particularly if an immersion heater is fitted.
I feel sure you are aware of the arguments that I could make.NT said:Lime said:I think there is a very strong argument to ensure that the hot and cold supply to the bathroom are electrically connected to each other if nothing else, particularly if an immersion heater is fitted.
Would you like to share with us what that argument is?
NT
Flyfisher said:Would it be correct to say that, yes, loads of earth bonding is a good thing (if in doubt, earth it?) but the RCD is the thing that will actually save you if, heaven forbid, circumstances arise whereby mains current starts to flow through your body?
Lime said:NT said:Lime said:I think there is a very strong argument to ensure that the hot and cold supply to the bathroom are electrically connected to each other if nothing else, particularly if an immersion heater is fitted.
Flyfisher said:While equi-potential bonding seems like a good idea, is it not almost certain that, in these days of modern plastic plumbing, it is almost inevitable that such bonding will be compromised sometime, somewhere?
Isn't it fair to assume that by far the best protective measure for any installation is the provision of RCDs to prevent people from receiving fatal shocks in cases where a fault arises?
I particularly like the idea of RCBOs fitted to every circuit, as previously suggested, and I assume that these devices can be selected with a tripping sensitivity lower than the 'normal' 30mA I've seen and used.
Flyfisher said:I understand a very sensitive RCBmight result in nusiance tripping due to 'normal' leakage currents. If 10mA is too low what would be a better figure, or is the standard 30mA adequate?
As for a 30mA RCB still allowing a 'very unpleasant' shock, it's the fatality of it that concerns me more than the unpleasantness :wink:
NT said:And frankly, retrofitting it to installations that unsafe brings as much risk as it abates. If you live with a dangerous installation like that, the only real solution is to sort it out.
NT said:One of the problems with them {RCDs} is that conditions are not identical, as users too often take full advantage of this apparent extra safety, and start doing things they never would have before, like using power tools outdoors in mild drizzle etc, thus negating any safety benefit and more.
