Flyfisher
- Norfolk, UK
I've been told that, under the new wiring regs, if any new work is undertaken then the whole wiring to the house has to be brought into line with the new regs, i.e. the new regs apply retrospectively. To my knowledge, this would be the first time that new wiring regs have been applied this way. Is this really true, or is our electrician trying it on?
One specific thing mentioned was that the new regs include things like specifying the number of sockets in each room, which I can understand for a new build but I find it hard to believe this must be implemented retrospectively.
The existing wiring is certainly not up to latest regs and is frankly a bit of a mess, but it is plastic (mostly, I think!) and does work and is just about adequte as it stands. But we're planning a new kitchen and this will require new wiring to be installed (existing room has only one single 13A socket!). I had assumed this could be done as two completely new circuits (cooker and ring-main) without touching any of the existing wiring.
I also believe it is OK to do all the wiring yourself as long as the final installation is independently certified. However, if I get someone in to certify my work, will they look only at me new wiring or will they treat the whole house as one installation and then refuse to certify it because parts of the installeion does not comply with the latest regs?
