Zebra
- St Albans, Hertfordshire
Well if you have a can of worms (rotten joists), there's no benefit in not getting it open, and if there is a further problem, better to know now before any builder can possibly, perhaps unknowingly cause more damage. So this elephant we have to eat a spoonful at a time.. first spoonful is doing something, anything, to support the brickwork as best you can, which yes, might involve holes in ceilings.... second spoonful is then giving the timber lintel a poke and a wiggle..... you might just find that oh! it's fallen out... (that's when you rush off to the builders merchants for a new lintel and shove it in quick!) but if it doesn't come out immediately you will see what is going to go with it, whether a couple of bricks are going to fall out, or whether the whole wall is now moving... the thing with this approach is that you can always abort and run away, but by proceeding carefully one step at a time, you can see what you're up against as you go along, and you're not at any time biting off more elephant than you can chew. Very chewy, elephants.Thanks zebra. I had thought about making a hole in the lath and plaster ceiling below and maybe propping the joists, but I’ve a horrible feeling I’ll find rotten ends and therefore open another can of worms. The room below contains 2 gas boilers and the compression vessel thingy. Eventually the weird 2 boiler system needs replacing, but it’s still working ok so not urgent! There’s also a big sink on a brick plinth against the house wall which would need removing to get props in. Not insurmountable. Perhaps you’re right-the lintel/former doesn't look like it’s doing much, but there are bricks resting on it, and from what feltwell said about self-corbelling maybe the worst that can happen is a few bricks fall out. But maybe a lot more! To get the new lintel into the 9 inch brick walls far enough and insert padstones or new bricks, I’d have to make some bigger holes, wait for mortar to dry etc. Making holes in the walls with nothing supporting the adjacent wall feels a bit scaryI’m rambling now, sorry!
