Lindyboo
- East Lindsey, Lincs
Can anyone recommend a double-glazing company who operate in Lincolnshire (East Lindsey district) - or give me hints on which ones to avoid?
Ta
Ta
That rather depends on the building. Flush windows were the norm until 1666 in London and much later elsewhere. Timber framed buildings usually have flush set windows.Roger H said:Anything pushed to the face of the building looks especially wrong.
You will have to comply with Part L of the Building Regs (unless listed or in a Conservation area), which almost certainly makes double glazing a must. If you are putting in a new window anyway, then the payback time of double as opposed to single glazing is very quick.rogerh said:Personally I wouldn't bother with double-glazing (and for uPVC ones the payback time is longer than they're likely to last), although unless you're listed you may not have the choice.
Albacks, the Swedish company that makes the Holkham Linseed Paint, say that after 7 years a coat of linseed oil should be applied and only after a further 7years should a single coat of paint be required. No stripping, sanding, flaking etc, just a 14 year minimal maintenance cycle. (Of course you can get a paint designed to coat uPVC when it goes all yellow and horrid.)rogerh said:If you use a linseed oil paint, though, (e.g. Holkham's http://www.holkham.co.uk/linseedpaints/why.html) they shouldn't need painting more than every seven years or so.
It depends on the size and complexity. You really ought to ask for a quote, though he'll probably say he's busy for the next few months.Lindyboo said:How does the cost of oak d/g compare with upvc - any ball-park figures?
rogerh said:By the way, are you sure your existing window is beyond repair? It's rare for any window to be that far gone and you may find it's cheaper to get a joiner to fix what's already there.
