1kg of white? Putty usually comes in 25kg tubs….I'm hoping 1kg of red and 1kg of white is enough.
Sadly whilst I rent a flat in one and work on them every day I do not own a period property, however, as per another recent thread, if you want proper honest, detailed advice (the industry is full of BS and received wisdoms) then call Ingleby.Afternoon all,
Finally got both kids bedrooms to a paint where they can be decorated. Been a bloody long process.
Anyways because we have two outside walls in each room, I've woodfibre boarded and lime plastered. I am now looking for the best kind of paint to stick on it?
Can somebody advise.
Kind regards
James
Ive just ordered an Ingliby colour cardSadly whilst I rent a flat in one and work on them every day I do not own a period property, however, as per another recent thread, if you want proper honest, detailed advice (the industry is full of BS and received wisdoms) then call Ingleby.
Possibly the most knowledgable people in the UK. The little hall and crooked house in Lavenham being two of the most famous medieval properties in the world, the latter owned by Suffolk Preservation Society, painted with Ingleby paints. In fact, I am reasonably certain that a large proportion of the buildings in Lavenham and Suffolk as a whole, home of the largest collection of medieval buildings in the world, are probably coated with Ingilby.
Ted Ingleby used to hand paint the colour cards, not sure if he is still with us. Before he started the business he was a top coating chemist working in UK, Europe and the Middle East and on proper technical stuff, like marine coatings. If you grew up in the 60s or 70s you have probably already used some of his products as he used to be a coating scientist at Humbrol.
He develeoped lime hybrids like interlime and pozilime which can go over lime and modern substrates.
Give them a call, then call the other companies.
I am a 37 year experienced finisher and I always trust a company that knows their technical stuff.
And.. lol, my two colour boxes of stains and pigments total around £1500.
Traditional earth pigments are fine, ie yellow ochre, raw sienna, burnt umber etc but they can be gritty and can require more diligent stirring, these are good as a base.
If you want to tint, you can use universal colour stainers, exactly the same stuff F&B and Dulux use. The best are Mixol, German, their parent company also make the pigments that go into auto paint. They cost about £15+ each per 200ml, the red of which would probably be enough to tint enough white limewash to make an entire house, or three, pink. And yes, they are magic, the go into both water based and solvent based finishes, fillers and glues, you might need to test with linseed oil based though, they can be tricky.
Final tip as a colour mixing expert (I can mix any colour paint or otherwise) firstly, you have to do a sample IN SITU on the actual substrate, as you would coat the entire area. Secondly wait until dry, which might be over a day. Thirdly, view in all lights, especially daylight. Fourthly, once you are happy with a sample recreate it in miniature and measure out and write down. Fithly, when you mix up your final mix make more than you think you will need and most importantly! Sixthly... when you do your big mix make it weaker at first! ie if making pink add less red, do a sample and 'creep up' on the pink, its easier to add a few drops more of red rather than dilute with another ten litres of limewash! And remember, yes, technically it is a science but infuriatingly there are so many variables it is also an art. Do not be surprised if you scale up your recipe and the large scale colour doesn't match your test sample! The most common reason is different application characteristics, for example if you are going to brush wash with a 6 inch brush 3 coats, then do that on the sample! If you are going to roller a finish, then do that on the sample, if you need to damp down then do that on the sample... it can be tempting to rush the sample, but don't! The more methodical you are the more accurate you will be.
For this reason (and the way your brain works in colour perception) your sample area needs to be at least 4 foot square (60x60cm) per each sample.
Mixol : Universal Stainer : 200ml : Red
Mixol is a binder-free multi-purpose tinting paste. Shake thoroughly before and close firmly after use so Mixol will not dry out or form lumps or skin. Mixol is highly resistant to frost and heat. After freezing it needs only to be thawed at room temperature. Then shake thoroughly and it is...www.handover.co.uk
Ingilby Paints | Home
Ingilby Paints are a family of traditional, modern & specialist paint makers. Our small workforce consists of 3 generations who have been hand producing paints for over 50 years.www.ingilby.co.uk
A genuine made in UK third generation family business run by passionate experts who make paints for old dwellings in an area with more old dwellings than anywhere on the planet, most of which are coated with their products. What could go wrong?Ive just ordered an Ingliby colour card
I think there is a photo of Little Hall on their website.A genuine made in UK third generation family business run by passionate experts who make paints for old dwellings in an area with more old dwellings than anywhere on the planet, most of which are coated with their products. What could go wrong?
FYI I absolutely love Little Hall Yellow, being possibly the second most famous building in Lavenham, not only did the Suffolk Building Preservation Trust blow a large two fingered rasberry to EH's usual insistance that all beams must be painted 1860's coal tar black, despite being 14th century by washing over everything, as would have been done. I think the colour is wonderful. Not sure if it's a straight raw sienna lightened by the lime or with a bit of yellow ochre added. It seems brighter than mexican yellow, less green than yellow ochre and less orange than straight raw sienna, I think it might be my favourite limewash colour of all! I'm not a huge fan of Suffolk pink!
1kg of red and white pigment, although it looks more like cream than white.1kg of white? Putty usually comes in 25kg tubs….
1kg of red pigment? that's a lot1kg of red and white pigment, although it looks more like cream than white.
well, I'm not sure there is anyone you can speak to at any other company with as much knowledge. That's what I go on. Marketing is all white noise to me. Show. Me. The. Money. ie can I speak to someone who can tell me what it's made of, how it's made, where it's made, how it works, how do you apply it, how it compares to other products and how it works at a molecular level?And thank you for the information Toby. I actually found the company with a Google research a few weeks ago. They look to be decent
also at the risk of being a ponce, get advice first, there is no such thing as red and white pigment!1kg of red and white pigment, although it looks more like cream than white.
I've not struggled with this - limewashed the whole house inside and out, couldn't possibly have mixed enough all in one go. My recipe is 1 15ml measuring spoon of pigment per coffee cup of putty, and you can't tell the batches apart...Make sure you make enough coloured wash for the complete job, you will struggle to blend exactly the same shade later on.
