Penners
- Suffolk, England
Wiggs - you've gone dotty!
Penners said:I would recommend using drawing pins to keep the parchment in place.AMc said:I wrapped them with silicone baking parchment
Penners said:Leave some parchment projecting each side of the hole/notch and then fold a flap of it down on to the face of the joist - and insert pin.
I'm afraid my limited imagination hadn't come up with that idea. Perhaps I'll try it and let you know the outcome.Moo said:Sorry, Penners; I thought you were advising pinning the parchment to the pipe.
The problem with that is it tends to create what we experts call "a leak". (Stop me if I'm getting too technical for you).AMc said:Pinning the parchment to the pipe?
Do I look like an idiot?
How would you get the pins through the copper?
You'd have to drill a hole and use a screw!
No, there's no leak in there; there isn't room for so much as a spring onion with all that water coming out.Penners said:The problem with that is it tends to create what we experts call "a leak". (Stop me if I'm getting too technical for you).
