Penners
- Suffolk, England
Wow - his and hers lofts. There's posh!Moo said:Penners said:But why one each - wouldn't he share?
We had two lofts, silly.
That alarms me.c r said:I think I've used the term 'water hammer' incorrectly earlier in this thread, in using it to also mean a loud knocking sound within the CH system, that usually happens a few minutes after my boiler is switched on. This has happened for years and years, without seemingly being too much of a problem, we always have taken it to be trapped air in the system being suddenly released as the water temp rises.
Ah, but that's exactly the point, Rob. "In all your years..." demonstrates your experience (and thus skill) as a plumber. A solder joint is the best, cheapest solution provided it is properly made. But in inexperienced hands, it can quite easily go wrong.robgil said:In all my years do8ing plumbing work i would never put in a compression fitting in favour of soldering it, they can leak, a properly soldered joint will be a much better long term solution.
Are you sure that's water hammer, and not just an extreme version of the clicking and ticking that many CH systems get, as the pipes expand?c r said:I think I've used the term 'water hammer' incorrectly earlier in this thread, in using it to also mean a loud knocking sound within the CH system, that usually happens a few minutes after my boiler is switched on.
Hmmm - if it's that loud, it sounds like rather more than pipe expansion. Have you tried tracing it to its source, while it's going on? It would worth doing so, and putting your hand (gloved if necessary!) on the guilty pipe to see what it feels like. You'll probably be able to feel expansion ticking, but it won't amount to much. Water hammer, on the other hand, will probably cause the pipe to jump noticeably at the location of maximum noise.c r said:Yes thats what I mean, I shouldn't have said 'water hammer' before, but certainly the noise is much louder than clicking or ticking- knocking or banging would be more accurate, its abit like a clap of thunder!
I've also used that solution to solve the noisy creaking that expanding pipes can make when they reside in holes or notches in timber. However I would recommend using drawing pins to keep the parchment in place. Sometimes the constant movement of the pipe as it expands and contracts can push loose parchment out of place.AMc said:I wrapped them with silicone baking parchment
