Lime
- East of England
If a meter jumps by 6000 units, either it was misread or is faulty. Or perhaps nothing but cinders remains of the house.
:lol: :lol: :lol: :lol: :lol:
Another good one!
Err... YesNT said:noflyfisher said:V and I do go out of phase as a result of this harmonic distortion.
But does it only work with wooden light bulbs?biffvernon said:Well I've got a dimmer switch but the plastic knob broke and fell off so I made a wooden one.
Penners said:But does it only work with wooden light bulbs?biffvernon said:Well I've got a dimmer switch but the plastic knob broke and fell off so I made a wooden one.
NT said:>Dimming a lamp is, by definition, the best way to reduce brightness
Its not the best way to reduce brightness of a light fitting or room lighting scheme. You're using the wrong definition. The best way to reduce lighting brightness is to switch on a lower power lamp instead, or switch on less lamps.
NT said:>> Normal dimmers dont produce reactive loads, v and i always stay in phase.
> We went through that discussion and concluded
Yes, I know what you concluded, and why it was wrong.
no
> So I'm not sure where the outstanding confusion lies.
I understand that. Dont make the mistake of thinking everyone else at the same level of knowledge as you are. I may be fairly uninformed on some topics, but not this one.
MdB said:Err... Yes
A dimmer that is switched on during the first and third quadratures and off the second and fourth powering a resistive load will phase shift the current relative to the voltage by about 30 degs (ish). I can either do the sums for you (a Fourier transform of the waveform) or sell you a piece of equipment that will allow you to measure it.
Note: The voltage and current seen by the resistive load will be in phase but the voltage and current powering the load and dimmer combination will not be. This is probably where the mistake is being made.
I never have this problem.MdB said:A dimmer that is switched on during the first and third quadratures and off the second and fourth powering a resistive load will phase shift the current relative to the voltage by about 30 degs (ish).
Well just don't tell your insurance company.Nemesis said:We modify ours by way of a nurdelsnooper valve.
At least you gave an explanation :wink:Penners said:I never have this problem.
I rely on a simple left-handed snib valve agitator to ramp the offline doobriferkin, sufficient to overcome the tensiary effect of the floggle-toggle.
I knew you'd understand it, Flyfisher.Flyfisher said:At least you gave an explanation
I don't recall saying I understood it, I was just thanking you for explaining itPenners said:I knew you'd understand it, Flyfisher.Flyfisher said:At least you gave an explanation
Gervase said:Oil lamp? On a weekday? Coo, 'ark at Lady Muck.
For us it's fork 'andles (with apologies to Ronnie Barker)
