Flyfisher
- Norfolk, UK
I'm sure there must be foxes around us but I've never seen one. If you have dog-walkers reporting bold-as-brass foxes during the day then it sounds like you have a bigger fox problem than us. Otherwise, perhaps we have just been lucky.
The fencing was a pretty easy DIY job and took about 3 days for a fence that used about 40 posts in total. I'm sure a professional would have done it in one day though! I used 1.8m, 2-3 inch round posts, which cost £1 each from a local sawmill. They can be banged into the ground fairly easily with one of those "post-basher" thingies. Use slightly thicker posts (straining posts) at the ends of each run or where the fence changes direction. Use the 2-3 inch posts as braces. Then run three strands of fencing wire between the posts; I think I used 4mm wire. Don't staple the wire tightly on the posts, the staples are only to hold them against the posts. Use adjustable wire tensioners at one end of the run. I prefer the ratchet type as they are easy to re-tension with a spanner if the wire stretches (which is why you shouldn't fix the staples tightly against the wire). Tight wires as essential for a good fence of this type. Then fix the 1.05m rabbit fencing to the fence wire using thin garden wire or the like and staple it to the end posts. Hey presto!
For some great information, look at the fencing book on here: http://handbooks.btcv.org.uk/handbooks/index. It will tell you everything you need to know in great detail and with excellent drawings. It can be a bit tricky to get the posts dead vertical but that's just an aesthetic issue. You'll also need a gate of course. I made mine as the first exercise for my newly-purchased morticer, but it's just as easy to make one with handtools.
Let me know if you need any more info.
