charlie-ia
- LANCASHIRE
thats a good start, thankyou. we're only able to get over for a couple of days the first time, so plenty to keep us going!
charlie-ia said:does anyone know the phone number for the sorcerers apprentice?
(probably copyright disney)
NT said:Aiden talks about a lot of tech & options that I dont see as useful for your case.
NT said:Right on all points aiui. My attempts to use refrigeration below 10C have been almost totally ineffective.
NT
Aidan said:NT said:Aiden talks about a lot of tech & options that I dont see as useful for your case.
Oh dear; NT's being rude about me. I must have upset him again.
NT said:I havent been rude about you at all. I dont see any need for that sort of carry on.
NT
Aidan said:Aiden?
Talks a lot about stuff of no use?
biffvernon said:How do the electronic humidity meters work?
I've not tried it either, but I doubt that a sensor designed for a very specific purpose (i.e. VCR or camcorder protection) would be a good starting point if you wanted to detect a wide range of RH for a dehumidifier-type application.NT said:I've not tried it and dont know the characteristics of the sensors,
biffvernon said:Ta. So just how reliable and accurate are the sub £10 electronic humidity meters? I happen to have one in my conservatory. The numbers vary from over 70% first thing in the morning when the temperature is very low, to less than 40% later in the day when the sun has warmed the place excessively.
Flyfisher said:I've not tried it either, but I doubt that a sensor designed for a very specific purpose (i.e. VCR or camcorder protection) would be a good starting point if you wanted to detect a wide range of RH for a dehumidifier-type application.NT said:I've not tried it and dont know the characteristics of the sensors,
On the basis that a humidistatic dehumidifier allows a degree of control over the RH level, thereby implying it can sense a range of RH, whereas a camcorder has no such control. Or, more accurately, a camcorder is really only concerned with detecting condensation, which can cause the tape to stick to the spinning heads with unfavourable results. The actual level of RH, per se, is not a problem for camcorders. You can use them in the desert or the rainforest with equal ease.NT said:Flyfisher said:I've not tried it either, but I doubt that a sensor designed for a very specific purpose (i.e. VCR or camcorder protection) would be a good starting point if you wanted to detect a wide range of RH for a dehumidifier-type application.NT said:I've not tried it and dont know the characteristics of the sensors,
On what basis do you say that? Not that dehumidifiers need wide range sensing.
