View attachment 1View attachment 2and a couple more... as you can see it is habitable... for now anyway !
Tell me about it and the wood panelling in the lounge .... its like plywood!Gareth Hughes said:Ooops
Aaaaargh!!!! My eyes!! it burns! it burns!
I know. No matter how hard I try, someone else always manages to pinch a slice or two.JoceAndChris said:you wax lyrical about Mrs P's amazing chocolate cake, you can't have it all, you know.
Cloudscape said:No no no... forget all the priorities... you have an emergency. Top priority is the knobbly stone edging on the arch around the range.
Oh Tell me about it!!Penners said:Well, having struck Mr Hughes blind, you've done me a power of no good, too. :shock:
The interior of the house looks to me like a perfectly valid excuse for the restoration of capital punishment. You've shown us quite a few photos - do make sure that you carefully photograph every detail of it before you start changing anything.
Just think of the satisfaction you'll be able to derive from the "before" and "after" photos in years to come!
Matt Green said:Cloudscape said:No no no... forget all the priorities... you have an emergency. Top priority is the knobbly stone edging on the arch around the range.
AIIEEE! someone did that, stood back and presumably thought "Yes. That was the look I was aiming for. Perfection."
Make sure you bring that important historical feature to the attention of the CO. I don't think II* does it justice. I want that range scheduled as an area of outstanding natural beauty.
Matt
-currently buying a Victorian place the Georgians have messed with. Collapsing dining room floor, so I'm happy. All estate agents should be hunted to extinction though. With dogs.
Either the house has suffered at the hands of some dodgy builders from Georgia, or you've got something of a chronological miracle on your hands, there, Matt. :wink:Matt Green said:currently buying a Victorian place the Georgians have messed with
Matt Green said:Matt
Penners said:Either the house has suffered at the hands of some dodgy builders from Georgia, or you've got something of a chronological miracle on your hands, there, Matt. :wink:Matt Green said:currently buying a Victorian place the Georgians have messed with
Fair point, but bodging can cause significant damage. Consider the following two photos of some roof timbers around a chimney. There was no lead flashing and rain would run down between the chimney and tiles onto the horizonal timber in the photo. This had been happening for many years, probably decades.AMc said:Consider before you condemn bodging, while it doesn't sound like the previous owners showed much care there are accidents, emergencies and the unsupervised contractor. Bodging a door with foam may not have been their first choice but sometimes circumstances force your hand to make a temporary fix and then live with it because you can't afford the time/money to do anything else.
Flyfisher said:Fair point, but bodging can cause significant damage. Consider the following two photos of some roof timbers around a chimney. There was no lead flashing and rain would run down between the chimney and tiles onto the horizonal timber in the photo. This had been happening for many years, probably decades.AMc said:Consider before you condemn bodging, while it doesn't sound like the previous owners showed much care there are accidents, emergencies and the unsupervised contractor. Bodging a door with foam may not have been their first choice but sometimes circumstances force your hand to make a temporary fix and then live with it because you can't afford the time/money to do anything else.
A few years before the photos, the leaking roof was 'fixed' from inside the attic using expanding foam, as can be seen around the right-hand side of the timber. I'm sure it fixed the leak into the attic but, of course, it did nothing to prevent water entering the roof. The second photo shows how the timber smothered with foam had completely rotted away within 2-3 years due to water being trapped by the foam whereas the timber remaining open to ventilation at least had a chance to dry out between showers and was still serviceable, albeit rather soft, after at least a decade.
